Opti, LTCC, Delteq, Dynaspark????
Old Jun 11, 2007 | 07:02 PM
Deenasty's Avatar
Well my TA just started messing up this morning, code 36 is present. Runs like turd! Im gonna be checking the opti harness before replacing the unit, but I would like to know which unit you guys reccomend. I have been out of the lt1 updates and releases for quite some time now. I wanted to go with Delteq because they sell the complete kit, but unfortunately it still needs the opti to function, so that would be $679 plus an additional optispark price. What do you guys reccomend, and where can it be purchased.. MODS IN THE SIG!
Old Jun 11, 2007 | 07:09 PM
Dave89IROC's Avatar
dyna spark sells the gen 3 finally, pretty much just the pick-up portion of the opti, for use with systems like the deltec
Old Jun 12, 2007 | 05:51 AM
f1camaro's Avatar
Well if it were me,i would get a new stock GM opti because you have a 95 which uses the vented style which is much more reliable,then get the Delteq setup and take the new opti apart and remove the rotor and then seal up the cap real good when you put it back on.Now if that is to expensive then you could just get a new Gm opti and hope you get a good one,which when it comes to the vented ones alot of guys do get alot of mileage out of them and of course some do not.
Old Jun 13, 2007 | 10:22 AM
The Engineer's Avatar
Originally Posted by camaroRI
I am thinking of replacing with the msd opti that just came out recently its pretty pricy but hopefully its good!
Your quote, "hopefully its good" A statement that falls in line with your's, "It's better to be lucky that good" Hopefully, you'll be lucky with your MSD opti, I wasn't lucky.
But I have my MSD opti problems (brand new distributor) figured out now;
1. Remove and replace the rotors screws and use some blue thread-locker.
2. Make sure the rotor is not rubbing (scraping) the back-plate.
3. Use the new MSD square gasket design, not the O-ring (it won't fit correctly no matter how good it is installed).
4. Hope like hell you're lucky.
Please read this MSD Opti thread!
WD
http://web.camaross.com/forums/showthread.php?t=525186
Old Jun 13, 2007 | 10:39 AM
Bow94z's Avatar
Yea i also was about to buy the MSD opti, But like a GM one, it's always a crapshoot. Im Waiting on a Dynaspark as we speak
Old Jun 13, 2007 | 01:24 PM
2000GTP's Avatar
I would probably just opt for another GM opti and save the money. The Dynaspark is an expensive piece and the Delteq and LTCC require the optical portion of the opti anyways, which you know you need to replace anyways.
Old Jun 13, 2007 | 03:52 PM
Deenasty's Avatar
how do you know its the optical side that went out on mine and not the cap and rotor side?
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
tommalcolm
Sep 11, 2015 03:39 PM
