opti or just cap & rotor?
Old Dec 12, 2007 | 08:14 AM
rjc1629's Avatar
I have been getting a high RPM miss ever since I spilled coolant all over the front of my motor. I am replacing the e-water pump with a stocker so I might as well address the opti while I'm in there. Can I just replace the cap & rotor or does the whole opti need to be replaced
Old Dec 12, 2007 | 12:54 PM
BrokeMofugga's Avatar
I just replaced the cap and rotor.like a year ago,and so far no problems
Old Dec 12, 2007 | 12:56 PM
jsetzer's Avatar
IMHO never ever replace just the cap and rotor. If you are going to have it apart replace the whole thing with a new gm piece. Don't buy parts store reman crap either.
Jason will ship you one for @ $235 complete.
Old Dec 12, 2007 | 01:00 PM
rjc1629's Avatar
How do I contact this "Jason" ?
Old Dec 12, 2007 | 01:13 PM
jsetzer's Avatar
Heaven forbid I put his contact info up, since hes not a sponsor.
His name has floated around forever on here though, Ill pm you.
Old Dec 12, 2007 | 05:22 PM
The Engineer's Avatar
Remove your Opti, open it up and take a look inside to see what is wrong. Normally, you'll be able to see the problem (loose rotor, coolant, Etc). If it was the high or low resolution pulses (optical sensor), you would be getting a code.
WD
Old Dec 12, 2007 | 05:42 PM
rjc1629's Avatar
OK I'll check when I dig into it, thanks for the help guys.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Nellsw88
May 27, 2015 10:27 PM
Nellsw88
May 26, 2015 05:55 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
