Opti issue?
Opti issue?
Hi. I have a very intermittent issue. Car runs and drives great. Rarely when I start the car it runs very rough, sounds like running on 4 cylinders of timing off. If I shut the car off and restart, everything is fine. It seems to be happening more often. No check engine light on. Car has a lot of miles on it. Vented Optispark with about 200k on it.
thank you.
94 z28.
thank you.
94 z28.
Re: Opti issue?
Try scanning the PCM. DTC 16 for loss of the low resolution Opti pulse signal can only set when cranking the engine, only if there is a high resolution signal to tell the PCM the engine is cranking (takes several seconds of cranking to make this determination), and DTC 16 does not turn on the SES light.
Re: Opti issue?
DTC 18 is for injector electrical faults. Unfortunately it doesn’t tell you which injector(s).
Key on, connector off injector, verify ~12 volts at the pink wire in each injector connector. Connector still off, measure the resistance of each injector, should be in the range of (roughly) 12-16 ohms. Verify exact range in factory service manual. Then reconnect injectors, start engine, and using a ‘noid light verify the PCM is supplying the ground to fire the injector. Going to be hit or miss if the problem only shows up intermittently.
Re: Opti issue?
thank you for your help.
Re: Opti issue?
Your comment about "sounds like it lost a bank of cylinders" makes me think you might be losing power from one of the injector fuses. There are two that each supplies half of the injectors. Might check them to be clean and tight. Or maybe one of the power supply wires from one of the fuses is compromised.
Re: Opti issue?
Re: Opti issue?
Hi,
lt looked like we just needed to crank a bit longer and it went away for awhile. Happened again to and repeated twice today . No codes logged. Stumped😢.
Recently replaced the cap, rotor and plugs. Found the Opti bearing a bit noisy. . just ordered a Petrie Opti and new wires.
Thank you,
Walter
Thank you,
Walter
