Opti help needed
Old May 26, 2006 | 03:53 PM
Eric_96Z's Avatar
Opti help needed
I am having my 96 LT1 rebuilt and the engine builder needs to know --on the opti if the notches on the back--if where it says #1 lines up with the notch with the small dot?
Old May 26, 2006 | 04:52 PM
Dave89IROC's Avatar
Re: Opti help needed
huh?
http://shbox.com/1/opti_back.jpg
Old May 26, 2006 | 07:18 PM
Eric_96Z's Avatar
Well I guess the tab is supposed to be in line with the #1, I guess you cant screw it up? is this the only way it will go?
Old May 26, 2006 | 10:24 PM
Red face Re: Opti help needed
If you read the note in the pic, it says the drive can be in any position and the marks on the back of the opti are just there for reference. If the special notch on the drive is pointing to 1 and your cam dowel pin is in a matching position, that means you are at #1 TDC.
I would be a little scared of someone building my LT1 that did not know how to put it together...
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
