Opti help needed
Opti help needed
I am having my 96 LT1 rebuilt and the engine builder needs to know --on the opti if the notches on the back--if where it says #1 lines up with the notch with the small dot?
Re: Opti help needed
http://shbox.com/1/opti_back.jpg
Well I guess the tab is supposed to be in line with the #1, I guess you cant screw it up? is this the only way it will go?
I would be a little scared of someone building my LT1 that did not know how to put it together...
