Opti Harness Part #?
Old Oct 8, 2003 | 01:44 PM
95 Z/28 LT1's Avatar
Super Moderator
I need the part # for my 1995 opti harness. I broke the clip that holds it plugged in to the opti when I took it out.
I know from searching that there is a part #12130319, but is it the one I need?
Thanks in advance.
Old Oct 8, 2003 | 02:23 PM
94 NO TOP Z's Avatar
Yes, that is the correct part#. (harness that plugs into the opti to the wiring harness on the passenger side of the engine). That little harness lists for $100 though Maybe get it for $60 or so from some discount dealers.
Old Oct 8, 2003 | 03:54 PM
Super Moderator
Is there more than one plug though? Vented & non-vented opti?
Old Oct 8, 2003 | 04:51 PM
Yes there are different harnesses. They don't interchange because of the length of the connector on the opti.
93-94 harness #12106559
Old Oct 17, 2003 | 10:45 PM
bowtiepwr's Avatar
>the harness attaches to the passenger side of the intake manifold and connects to another harness ... ?
is this correct ? are all the harnesses inter-connectible regardless of the connector at the Opti ?
Old Oct 17, 2003 | 11:37 PM
There is a slight difference if you are converting to a vented opti and change the harness. At the connector on the side of the manifold, you have to make a notch for the other connector to fit. The overall size of the connector is the same, though. I hope this is what you were asking.
Old Oct 18, 2003 | 06:29 PM
bowtiepwr's Avatar
>That is exactly what I was talking about
Thank you ... I will probably make the notch instead of swapping ends like the original plan .
HectorM52
Jul 30, 2017 11:46 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
