opti. different kind of question
Old Mar 3, 2008 | 09:53 AM
Pontiac_97's Avatar
can a bad opti still provide spark to the plugs but not let the engine actually fire or start up? is that even possible?
Old Mar 3, 2008 | 12:10 PM
Pontiac_97's Avatar
anyone???
Old Mar 3, 2008 | 12:23 PM
white97T/A's Avatar
Your question is a bit vague, but from the sounds of it - No.
If you are getting spark, I would look for issues elsewhere. Have you checked your fuel pressure?
Old Mar 3, 2008 | 12:41 PM
SS RRR's Avatar
depends on how it's bad. if it's a loose rotor then yes the engine can fire, but will not run well. if it's a bad optical sensor then it will not fire.
Old Mar 3, 2008 | 03:34 PM
If the opti is not installed (phased) correctly, you may have spark, but no start.
grgguy
17
Feb 23, 2015 07:57 PM
Lonemechanic
Feb 19, 2015 10:29 AM
94Form
Feb 10, 2015 11:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
Matt-01-SS
Aug 2, 2002 04:05 PM
