Opti dead?
Old Aug 7, 2005 | 11:58 AM
NuMbNuTs670's Avatar
Opti dead?
I was driving around and then my car just shut off. I have fuel pressure and a good crank but no spark coming out of the coil. I'm thinking its the opti but is there anyways to check if it is?
Old Aug 7, 2005 | 02:01 PM
slopokrodrigez's Avatar
Re: Opti dead?
First rule out the coil. Measure the voltage at the coil on the pink wire. Measure continuity from the coil to the ICM on the dark green wire. Check ground on the black wire to the ICM. Last, crank the engine and check the white wire going to the ICM for 1 to 4 volts on the AC scale. Then let us know what you find.
Old Aug 7, 2005 | 10:30 PM
HBHRacing's Avatar
Re: Opti dead?
http://www.mainstreamtopics.com/foru...p?showtopic=78
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
