Opti Contact vs cylinder
Old Jun 23, 2003 | 11:03 AM
atlasengr's Avatar
Question Opti Contact vs cylinder
With the opti dissected, and the contact for the rotor facing you and the opti in the installed position, what contact belongs to what cylinder? The first one starts at around 11 o'clock and then goes on in a full circle. This if for a 94 model opti. I have dealt with the 95 which is labled in the rear and helps you a bit more. Thanks for the help.
Old Jun 23, 2003 | 12:07 PM
badblackz's Avatar
I'm not sure, but for assembly purposes it doesn't matter. The rotor only goes on one way and locates itself through the splined shaft that drives it. There is a keyway on both ends of the shaft and it only goes in one way. Anybody, correct me if I'm wrong.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
buschman
Sep 8, 2002 04:03 PM
