Opti cap and rotor ?s
Old Aug 17, 2003 | 06:40 AM
revtime's Avatar
I have a 94 Z28 with the older style opti, I just picked up a new cap and rotor and it has the vent tube for the vented opti.
Can I use this on my older style opti? Plug the vent up or something or should I take it back and try to get another?
It looks like the mounting points are the same, I would just need to plug the vent tube.
Old Aug 17, 2003 | 06:46 AM
predator's Avatar
i beleieve so
Old Aug 17, 2003 | 07:21 AM
Re: Opti cap and rotor ?s
It will work. I don't think they sell a non-vented cap. I hope the cap and rotor are all you need.
Old Aug 17, 2003 | 03:47 PM
revtime's Avatar
Thanks Shoebox.
I dont have any opti codes and the whole motor is getting replaced next year and I am having classic cap and rotor problems since I am not sure what opti I will end up with (I am leaning towards a vented conversion) I was just gonna replace the cap and rotor and hope it lasts for another 15 to 20k.
If I see some obvious major problems then I will spring for a new optical portion as well.
Will it be all right to plug the vent with a rubber nipple and then put some clear RTV around it to make sure no water gets in?
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Nellsw88
May 27, 2015 10:27 PM
Nellsw88
May 26, 2015 05:55 AM
