opti apart, shows signs of arcing
Old Apr 18, 2003 | 07:54 PM
97 SLP Company Car's Avatar
Ok opti's apart and I can see that rotor is worn out(90000) miles and also can see visible signs of acring across at least 4 of the terminals, or what ever you call them.Everything is clean and dry and no signs of anything other than excessive wear.I'm hoping seals on the shaft can be bought or o-ringed can anyone help me here, the inner seal fell apart while I was holding opti taking it apart.
Old Apr 18, 2003 | 08:10 PM
90k miles- it's time for a new one. IMO, I would not bother with trying to fix anything. $190-ish from Jason or Dal.
Old Apr 18, 2003 | 09:56 PM
kjlvilla's Avatar
If it's been arcing (carbon tracking) then replace it. The spark will follow those tracks after a while. Sometimes the arcing gets bad enough to take out the optical sensor. You may or may not see this depending on how bad it was.
Old Apr 18, 2003 | 09:59 PM
Rodrigues's Avatar
BTW: 4 of my terminals showed signs of arcing as well, not worth "fixing" in my opinion.
Old Apr 18, 2003 | 10:24 PM
Remember, this is a distributor cap and rotor. There is going to be some wear on the terminals from the voltage and they don't last forever. Actually, I am surprised that some last as long as they do. Who would ever think of leaving a distributor cap and rotor on an old SBC engine for 100k miles?
Old Apr 18, 2003 | 10:30 PM
Rodrigues's Avatar
I actually found metal shavings in mine after 98k. I thought it was dirt but I took a closer look and its metal! I think after my bearing calapsed the rotor actually hit the terminals.
ChrisFrez
Mar 22, 2015 07:00 PM
cmsmith
Mar 16, 2015 02:34 PM
Feb 13, 2015 07:37 AM
ChrisFrez
Jan 11, 2015 03:47 PM
Collector Car
Jan 5, 2015 10:58 AM
