opti ???
Old Mar 12, 2008 | 01:49 PM
  #16
jsetzer's Avatar
I suggest ALWAYS replacing the entire opti, not just the cap and rotor when you change them.
If you can log it you should be able to see if its the optical portion - In fact it would even show on your tach. I have had it dance like crazy when the pick up portion of the opti went bad. Could be cap/rotor related too - I have not had good luck with them lining up and fitting properly when just replacing a portion of it. Accel cap/rotor on a gm base chewed up the rotor on mine.
I will still tripple check plugs and wires though. Crack in a plug could do it.
Old Mar 12, 2008 | 02:11 PM
  #17
northdakota93z28's Avatar
i just put new plugs and wires, i drove the car open header to the equast shop and the same day i had the stall put in and that is when it started, the tach just stays at 4100 rpm for like 8secends and if i keep it wot it will get past the stumble and shift. it is weird that it ran great open header and after 60 miles and the new equast and stall that it started the stumble?
Old Mar 12, 2008 | 02:37 PM
  #18
well i guess i will have to take off my opti tonight and see what it looks like?? i am to the point that i want to burn the car down!!
Old Mar 12, 2008 | 02:39 PM
  #19
http://cgi.ebay.com/ebaymotors/OEM-L...em320227526712
what do you think of this opti??
Old Mar 12, 2008 | 02:40 PM
  #20
or
http://cgi.ebay.com/ebaymotors/93-94...em120232039623
Old Mar 12, 2008 | 06:53 PM
  #21
ss.slp.ls1's Avatar
The second one has part numbers which is good, but at that price I would beware.
Old Mar 12, 2008 | 08:49 PM
  #22
ya it might be too cheap.
i took the car out tonight and i unhooked my digital6 and put avgas in it and it did the same thing. what i dont understand is how the thing can just fry the tires and second gear is super strong and third stuble, y if it was the opti would it not act funny in 1st and 2nd?
Old Mar 12, 2008 | 08:56 PM
  #23
MeanGreen97Z's Avatar
Sounds like you may have fried some wires. Check the wiring harness on the passenger side of the engine bay that runs down along side the shock tower.
Old Mar 12, 2008 | 08:58 PM
  #24
i will take a look.
Old Mar 13, 2008 | 03:34 PM
  #25
i am going to get a cable so i can do a data log and i will c what happens.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
