Opposite Temp prob.....at least thats what i think
Old Dec 7, 2006 | 10:04 PM
burnout96's Avatar
ok, its been a week now, after a call into jegs, ordered a 180 thermostat, replaced it, car still kicks SES light on right as it hits peak temp *180*, fans kick on and do NOT kick back off, no preformance differences, everything it running fine, could it be water pump? heater core? ne suggestions please guys help, only shop with OBD I around here is FitzMall, that would run $80 for them just 2 look at it...ive checked all sensors and all seem 2 be fine....
car is 94 z28, m6, with 52,000 on it *original*, no preformance mods, *there still sitting in the basement, LT's, SLP LM, ELE CUT,
aim is proc2k3 if neone can help
Old Dec 7, 2006 | 10:19 PM
JP95ZM6's Avatar
I doubt if you WP is shot since the temp stabilizes at stat temp with the fans on. If it's stock and not leaking bad out the weep hole it is very likely fine. Sensor problems can cause the PCM to defalt to 'fan on'. Also, I think you go into closed loop about that temp. Could be something wrong with 'closed loop only' compononts, like O2s?
Around here we have Murray's, they have a tool loaner program where you can buy any tool they carry, (ie scanner) use it for as long as you want, then take it back for a full refund. See if you can find a parts store with that program around you, then drop a scanner on a credit card and return it when you are done. No money out of pocket.
Old Dec 8, 2006 | 03:29 AM
SS RRR's Avatar
You have a PM with a shop who can scan OBDI for a lot better price than that...
You need to get it scanned before you start throwing more parts at it. If you are still running stock fan temp then your peak operating temp is higher than 180*. More like 210*...
Only problem being is I don't know if they have a OBDI cable... but it's definately worth the call!
Autozone does the same thing.
Old Dec 8, 2006 | 07:22 AM
You need to get it scanned to see what the code is. Not sure why you changed the thermostat. 180° is the stock thermostat rating.
Old Dec 8, 2006 | 05:31 PM
burnout96's Avatar
sorry been at work all nite, overnite agh.... im gonna try n get it checked out 2mrw, therm is 170 now not 180, and everything else is stock, but thanks for the msg, though im gonna call them 2mrw, damn obd I, ill repost after i get it scanned...ohh and should i tell "Jeff" that someone sent me?
Old Dec 8, 2006 | 05:56 PM
SS RRR's Avatar
tell Jeff I sent you... he'll probably give you a big heavy sigh and say i'm a PITA, but he's a good guy no matter what he says about me.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
