Opinions and ?'s on torq thrust 2's for my z
Old Dec 12, 2003 | 10:07 PM
RNokes's Avatar
Exclamation Opinions and ?'s on torq thrust 2's for my z
I am in the market for rims for my 94 z28. The set that has caught my eye are the american racing torq thrust 2's. The size iam looking at is 17x8. Could anyone tell me if this is too big, will it rub or damage anything. What would the backspacing and offset have to be in order to have the wheel fit correctly. This is a daily driver car and would want to know if bump stops are needed on a 17 inch wheel.
Old Dec 12, 2003 | 10:18 PM
badazzcamaro97's Avatar
I'm not sure on backspacing, but the offset is 55mm. There shouldn't be any rubbing or anything if you use 245/45/17 or 245/40/17 sized tires.
Old Dec 12, 2003 | 10:21 PM
onyxblackz28's Avatar
I like the way these rims look on Camaros. And just about anything. I want a set myself. (alas just another poor college guy) The 17's aren't a problem. but you may want to look into getting 17 x 9.5 since they will fit, may as well go wider.
Old Dec 12, 2003 | 10:54 PM
97WS6SCharged's Avatar
I'm using a set of AR TT II's on my 97 Trans AM. I went with the ones for a 86-96 vette. They stick out about a half inch more than stock, but they look great. They are 17x9.5 with 275/40/ZR17 tires all around. PM me if you want a pic or two.
Old Dec 12, 2003 | 11:08 PM
Do you know what the backspacing is on your 17x9.5s
Old Dec 12, 2003 | 11:28 PM
My 97 Z28's Avatar
I run 17x9.5's and have no problems. I recommend going with 18's since they will also fit.
Old Dec 12, 2003 | 11:56 PM
I'm not exactly sure of the back spacing. They make the rims for the F-body.
Taken directly from the American Racing web site.
http://www.americanracing.com/wheels...shed&section=V
Part No.
505-79563
Size
17x9.5
Offset
46
Backside
Bolt Circle
5x4.75
Note
93-on Camaro/Firebird
Old Dec 13, 2003 | 01:16 AM
camaro79323's Avatar
tt2
i have a set my self on my 97. no problems here i have 9.5 in
front and 11's out the back also 17's
Old Dec 13, 2003 | 03:16 AM
93formula's Avatar
TT2s are played out get something else!! and this should be in the appearance section.
Old Dec 13, 2003 | 04:53 AM
Compstall's Avatar
I also have 17x9.5 TT2's. They fit just fine, and I like 'em. Pics are in my sig.
Old Dec 15, 2003 | 07:16 PM
RNokes's Avatar
i wanted to thank everyone for the replys and also to say sorry for posting in the wrong message board. How much did you guys pay for your torq thrusts? Thanks Ryan
Old Dec 15, 2003 | 07:33 PM
Compstall's Avatar
I got mine used with tires (only a couple thousand miles on 'em) off a guy on this website for CHEAP!!!!
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
realistyc
Jul 28, 2015 07:32 PM
