opinions for most power with these requirements
Old Dec 20, 2003 | 07:50 PM
NewbieWar's Avatar
ok these requirements...
Smog legal (california)
Natural asperated (last option)
will be daily driver...
so i will probably pull my motor out and get a few renches together... what all should i do while im in there... i wanna build it as powerful as i can. it'll probably be in a year or so when the car is paid off, thats when i'll have no money issues. but i wanna get a under 12 seconds if i can.
its stock. at the moment.
Old Dec 20, 2003 | 07:54 PM
Zack's Avatar
you wont need to pull the motor and go all out to go sub 12's. Just a good head/cam combo
Old Dec 20, 2003 | 07:56 PM
NewbieWar's Avatar
let me deck it out... sorry im a newbie to how much power cams add... but i wanna reinforce whatever to handle supercharging (much later down the road) and get as quick as i can.
i wanna change the valve springs and what not to get to 6500 rpms...
Old Dec 20, 2003 | 08:22 PM
Spinner's Avatar
305 cam
Longtubes (Mac midlengths or the good SLP shorties if you cant pass visual)
Hi flow cat
3" Y pipe,
3" cat-back
2800+ (as high as your comfy with) stall converter
CAI
Ported Heads
~350+ rwhp, mid-low 12s, emissions friendly
Old Dec 20, 2003 | 08:54 PM
my94blackz's Avatar
Light is the key word. Light rods but not aluminum, plus they have to be strong. I myself wouldnt go past a 4.030 bore due to cylnder wall thickness. Probably a 9.5:1 to 10:1 CR if your gonna supercharge it. tiny cam if emissions is that bad.
Old Dec 21, 2003 | 03:21 PM
NewbieWar's Avatar
why dont i want a high compresssion ratio for supercharging it?
would supercharging give a lot more power with higher compression ratios?
what accually defines the compression ratio? isnt that mostly based upon the heads and the cam?
also w/ h/c combo, lt4 valves and springs intake and whatever else lt4 includes excluding cam and maybe head., 383 stroker kit, supercharging
what kinda flywheel hp would i expect?
Old Dec 21, 2003 | 03:28 PM
Zack's Avatar
www.howstuffworks.com will start you out with some basic knowledge of engines. and a search will net plenty of reading to learn from
May 1, 2015 01:14 PM
XtremeLt1
Sep 13, 2002 08:50 PM
Omega9
Aug 2, 2002 12:33 AM
Wilson
Jul 21, 2002 05:08 PM
