Opinions On Changing Oil??
Old Aug 13, 2003 | 05:09 PM
InjectedSS's Avatar
when do u guys think is the best time to change the oil? when the car is HOT or COLD??
HOT because the oil will flow better?
or
COLD cause everything has settled to the bottom of the pan?
Old Aug 13, 2003 | 05:11 PM
jasons93z's Avatar
warm I let it sit for about 20 minutes before i change.
Old Aug 13, 2003 | 05:15 PM
ZDriver96's Avatar
every 3000
Cold so you dont burn your hands and get hella hot under your car.
Are you sure oil flows easier when hot?
Old Aug 13, 2003 | 05:17 PM
BUBBA's Avatar
I'd say good and warm too. Afterall, Jiffy Lube doesn't wait for them to cool down.
Old Aug 13, 2003 | 05:18 PM
InjectedSS's Avatar
Originally posted by ZDriver96
every 3000
LOL neways actually i change mine like every 2k...
yea it seems like when its hot its like water flowing out of there and when its cold its like REALLY slow.. which is weird cause when its hotter the oil is supposed to get thicker and what not
Old Aug 13, 2003 | 05:23 PM
InjectedSS's Avatar
well i hope u dont know this from experience
friends dont let friends take their cars to rip me off lube
Old Aug 13, 2003 | 05:44 PM
FastZinTennessee's Avatar
You need to change it with the oil hot. I change my oil after the car has run for at least 20 minutes, I even let the car idle while I'm getting the ramps out to put it on, and then as soon as I turn off the motor I'm under there draining. When your oil is hot all the "contaminants" that you want to get out are suspended in there. If the oil is cold the contaminants may have floated to the top or bottom etc.
John
Old Aug 13, 2003 | 07:53 PM
KwikistZ's Avatar
Also to get the REST of those 'thingys' out, its a good idea to flush a 1/2 or 1 quart through before you plug it again, thats what I did!
Old Aug 13, 2003 | 07:58 PM
Silver's Avatar
John
I agree with this only if you leave the plug out for about an hour so all the oil can make it's way back down to the pan. At that point, I'd be afraid moisture has worked it's way up into the pan or a fly... or beetle... or gosh darn near anything.
I favor draining when it's cold. That way I know everything has made it's way down to the pan (or all that's gonna at least).
I'm no expert on the oil's route through the engine and filter, so if I'm missing something, feel free to correct me
Old Aug 13, 2003 | 08:11 PM
Well I usually leave the plug out of it for a good half hour, and even if moisture gets in there it will just burn off. However, about getting other things in there....... I guess anything is possible! In my last car I did an oil change and a leaf came out of the hole
John
Old Aug 13, 2003 | 08:14 PM
jasons93z's Avatar
John
a leaf . that would scare me.
Old Aug 13, 2003 | 08:19 PM
Silver's Avatar
John
LOL are you serious? I can imagine it now... "Sir, I would recommend a flush"
"Son, don't try to scam me. I'm not paying for that CRAP!"
"But Sir...."
"Son, you'd better shut it and finish her up before I sock you one!"
"But..."
"Son! I'm not gonna tell you again!"
"Sir, LEAF!"
"Huh?? What you say boy?"
"LEAF - oil pan - bad, sir"
"Uhhh..... son, say what?"
Old Aug 13, 2003 | 08:51 PM
InjectedSS's Avatar
"But Sir...."
"But..."
"Sir, LEAF!"
LMFAO bwahahahahahahahahahahahahaha
Old Aug 13, 2003 | 08:56 PM
tehehehehe
Old Aug 13, 2003 | 09:01 PM
MellowZ's Avatar
I always change it when it's hot. Last time I replaced the plug with a Fram SureDrain thing. Think that should make for an easier/cleaner job next time.
