Opinions
Opinions
LT1 Short block
Crank
Scat #435010L - 4340 Forged
$630.00
Connecting Rods
Scat #6570021 - 4340 Forged H-Beam rods
$399.95
Pistons
JE Piston #131636 - Dished -22 4.030"
$775.00
(Ring set - J100F8-4030-5)
$98.00
Main Caps
Pro-Gram #SB350C22 - 22* Splayed Main caps (3 center caps)
$226.13
Main Cap studs
ARP #ARP 234-5601
$83.95
Bearings
Main bearings: Federal Mogul #4663M - Tri metal
$26.95
Rod Bearings: Federal Mogul # 8-7100CH
$54.95
Crank Hub
Jegs #055551607 - Keyed crank hub.
$79.99
Other than needing new pistons, is this a good setup for a future boosted 383? I will be running LE2s on top. The guy wants 2500 for it.
Crank
$630.00
Connecting Rods
$399.95
Pistons
$775.00
$98.00
Main Caps
$226.13
Main Cap studs
ARP #ARP 234-5601
$83.95
Bearings
$26.95
$54.95
Crank Hub
$79.99
