Opinion on current mods? What Next?
Old Nov 14, 2008 | 08:52 AM
cammed SS's Avatar
Ok guys im going to be brave and post all the mods done on my car. Im wanting yalls opinion on what has been done and some advice on what to do next. Also is there anything Ive should have done differently? The car is a 97 camaro SS.
Lets start with interior
interior changes:
New carpet (ebony) was tan
Removed back seat
Removed broken dash pad
M6 short shifter
Free mods:
A/C delete (removed all ac components added ac block off plate)
EGR DELETE
AIR injection DELETE
Ported descreened MAF
TB Bypass
Electronic and Ignition:
Accel Optispark
Accel Super Coil
MSD Super Conductor Wires
A/C Delco Iridium Plugs
New ECM w/ Dyno Tune
Suspension, exhaust & Rearend:
Spohn SFC's
Spohn LCA's and PHB
Lakewood Driveshaft Loop
Random Technologies Adj. Torque Arm
SLP Springs w/ Bilstien stage 2 shocks
SLP 2OTL w/y pipe, no cats, no rear o2's & PS LT's
Rebuilt 10 bolt with Motive Performance 3.73's
Engine & Bolt ons:
BBK 52mm Tb
Canton Tall Valve Covers
Lunati Lifters
CC Magnum hardend Pushrods
Pro Mag full roller rockers 1.6 intake/1.5 exhaust
CC-306 544/540 (Didnt touch the heads do to budget build)
CC918 Beehives
GMP Extreme Heavy Duty Timing Chain Kit
Moroso CIA w/new filter
Exterior Mods:
SOLD my SS HOOD (dont know if im going to regret this or not yet)
Currently running stock z28 hood but will eventually replace w/ Cowl hood
Exterior Thoughts:
Trade my 97 SS spoiler for 98+ SS spoiler
Trade SS wheels for somethng new
New paint
Ok before anyone asks yes my car is a true SS but had to change out CAI because I couldnt close the hood with the new valve covers. Thats also why I elected to sale the hood.
Thanks Lets here it
sean
Old Nov 14, 2008 | 08:57 AM
Mikie's Avatar
Heads next...then retune.
Old Nov 14, 2008 | 09:34 AM
Z-RATED94's Avatar
I have to agree. Nice set-up so far, wake that puppy up even more with the heads and tune.
Old Nov 14, 2008 | 09:52 AM
cammed SS's Avatar
I would love a set of heads but they are very expensive. Anything else I could do other than heads at this point? Thats less dough. Im not even considering spray so leave that out.
If I were going to do heads would a set from Loyd be the best bet? was thinking LE2's but I have new springs and pushrods that I hate to see go to waste.
Old Nov 14, 2008 | 10:19 AM
Mikie's Avatar
Ok, What about a good set of weld draglite skinnies and slicks / DR for the rear?
Battery relocation?
Old Nov 14, 2008 | 10:24 AM
cammed SS's Avatar
Ive been thinking about the battery relocation kit but does that really help alot? Another thing I thought about are the LCA relocation brackets. Thoughts?
Old Nov 14, 2008 | 11:25 AM
krillformula's Avatar
Any reason you are running 1.5 rr's on the exhaust side? I would run 1.6.
Old Nov 14, 2008 | 12:50 PM
cammed SS's Avatar
Running 1.5's for peice of mind. Your not going to gain much by running 1.6 on exhaust side but u take more of a chance with valve clearance. I didnt want to have to worry about piston slap. It also helps even out the cam hence my cam #'s.
Old Nov 15, 2008 | 01:11 PM
94SLUG's Avatar
HEADS HEADS HEADS!!! Cant breath cant make power... You should be able to have your heads worked for under 1k no problem.... 1.6rr is fine... Also Accel products are just total crap IMO, try to stay with Delco...
Old Nov 15, 2008 | 02:42 PM
LaredoZ28's Avatar
U have a nice setup already. you may wana try underdrive pullies.
Old Nov 16, 2008 | 07:05 AM
cammed SS's Avatar
[/QUOTE]...Also Accel products are just total crap IMO, try to stay with Delco...[/QUOTE]
Boy do I know, If I had to do it over again I would have bought the MSD opti. This one ive got ive had to already change once and it was only 3mths old when that happened. It was replaced for free from summit under warranty but when asked to replace for different brand they said NO. So long story short Im stuck w/ it until it breaks again and my warranty is up.
Laredo,
EEEHHH from my research I have found that the underdrive pulleys aren't worth their weight in gold. You also have to buy a shorter belt when installing and heard some cases where it affects your charging system in a BAD way. Thanks for the input though. KEEP EM COMING GUYS
Old Nov 16, 2008 | 12:18 PM
LaredoZ28's Avatar
Originally Posted by cammed SS
Laredo,
I have underdrive pullies on my car and it charges fine. you have to get the alternator pulley and the crank pulley for it to work the right way. I cut my belt and took it to oreilly and matched it for the right size i needed. I've also heard underdrives takes .1 off ur ET. I'm a racer so any time off my ET the better in my opinion.
Old Nov 16, 2008 | 12:31 PM
seawolf06's Avatar
wrong forum...
Old Nov 16, 2008 | 12:55 PM
cammed SS's Avatar
Originally Posted by seawolf06
wrong forum...
huh?
Old Nov 16, 2008 | 01:04 PM
seawolf06's Avatar
interior changes:
Removed back seat
M6 short shifter
Free mods:
EGR DELETE
TB Bypass
Accel Optispark
Accel Super Coil
Spohn SFC's
Spohn LCA's and PHB
Engine & Bolt ons:
BBK 52mm Tb
Lunati Lifters
CC918 Beehives
Exterior Mods:
Exterior Thoughts:
New paint
Where is your engine tech question? Should move to general F-body forum.
