OOps - Seatbelt Light
Old Aug 15, 2003 | 03:53 PM
TobyZ28's Avatar
I was fiddling with my car alarm to troubleshoot another problem, ended up just pulling the fuse to the alarm so it would stop beeping. Anyhow, when i put everything back to gether i noticed my seatbelt light is stuck on. Any idea's on which wires i should check to get it back to normal? I had no clue where to look when i tried to go back and fix it
Old Aug 15, 2003 | 08:08 PM
Fbody1's Avatar
under the driver 's seat there is a 2 wire plug, don't rember what color they are , but if you unplug it the light should go off, check there to find the wire's, if you unplug it and the light don't go off trace them to the dash , mabey you cut one on accident?
NewsBot
May 18, 2015 02:20 PM
dluna333
15
Mar 13, 2015 12:30 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
