Only idiot to break something during tb bypass
Old Aug 11, 2006 | 07:21 PM
Z28LT1_Just_Nasty's Avatar
Right next to the steam pipe is some wire going into the TB. I broke the bracket that it clips into, although it goes in and stays in; it no longer clips into place. What sensor is this?
Edit: It's right above where the steam pipe goes into the tb.
Old Aug 11, 2006 | 07:24 PM
n2ceptor's Avatar
Re: Only idiot to break something during tb bypass
http://shbox.com/1/throttle_body2.jpg
Could only be 1 of 2 things.....
Old Aug 11, 2006 | 07:26 PM
TPS thats what I thought... thanks. How much would it be to replace one? It still works I just worry about the wire falling out while I'm driving.
What could happen if it falls out while driving around?
Old Aug 11, 2006 | 08:36 PM
LT1_383's Avatar
It's unlikely that it would fall out while driving but it is of course a remote possibility. Nothing too bad would happen as a result. But to replace, it GM sells pigtails that you can use. You can splice the connector back in, or remove the pins from the original connector and push them into the new one once you remove the wires that came with it. Shoebox has a list of part numbers for various pigtails on his site. Shouldn't cost more then $25 or so.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
Bxlt1
Sep 29, 2015 03:18 PM
