Only 5-10 RWHP from Dyno Tune????
Old Oct 21, 2003 | 12:19 PM
  #16
RedPhenx's Avatar
maybe he is just being conservative so you dont feel let down if it isnt a big jump?
Old Oct 21, 2003 | 02:27 PM
  #17
BUBBA's Avatar
Throw it on the dyno for a couple runs. With your setup, probably should be around 360-375.
If any lower, you should be able to benefit from a dyno tune, since you have one available.JMHO
Old Oct 21, 2003 | 03:03 PM
  #18
brain's Avatar
Another thing, most people only look at peak numbers. What if the a/f ratio comes back inline on the top end and power is where it should be. You could still pick up alot of midrange power and torque. We dyno tuned my friends stroker mustang, its a/f was below 10:1 until 5000 rpms so peak numbers were ok. It gained 30 ft/lbs of torque across a range of nearly 2000 rpms. That WILL make a difference at the track. Also, drivability. Your car could run fine WOT, have a near perfect a/f ratio and next to perfect timing. However, it could run like poo. All those things are what you are paying for and what makes a dyno tune worthwhile.
Old Oct 21, 2003 | 03:09 PM
  #19
RealQuick's Avatar
Exactly right about power/torque across the rpm range. Thats what I was saying. If you look at my numbers I posted on page 1, you'll see I gained 30+rwtq down low!
Old Oct 21, 2003 | 03:14 PM
  #20
BradZ28's Avatar
Good points.....makes the decision a little more difficult, huh
Old Oct 21, 2003 | 03:28 PM
  #21
RealQuick's Avatar
Not difficult. Get the dyno tune!
Old Nov 2, 2003 | 11:29 PM
  #22
Highlander's Avatar
Honestly.. mail tunners cant beat a dyno tune.. not because they dont know, but just because they are not there.. they tune blindly.. and they resource themselves with tunning files that they make from dynotunning so there shouldn't be much difference, but even still, no 2 cars are the same nor will they react the same way.
But I have gained on 2 local cars that had a bryan tune over 24rwhp on the lowest... does that mean bryan doesn't know how to tune? NO! it just means that bryan is not here to see knock, is not here to feel the ambient temp or to see what the car is doing.. if you send him during 20 days 20 different logs he might get it where it should be, but being on a dyno is much more easier, but how much hassle would it be to do that???
Get the dyno.. you should start with the mail order tunning since it will be the PERFECT base tune to start
HarleyZ28
Oct 5, 2015 06:23 AM
Stay Puft
Middle Atlantic
Apr 19, 2015 11:39 AM
chevysam
Jan 16, 2015 07:45 PM
Burn_Out
Aug 18, 2002 08:49 AM
