One more time....what cleaner do i use on the TB
Old Jul 9, 2003 | 03:01 PM
Blue96z28's Avatar
i've heard all the horrior stories and such, im just looking for a straight answer....i plan to take my TB off the manifold to clean it.....what cleaner should i use??? Also some say that the butterfly's need to be lubed after its cleaned, what lube should i use as to not collect alot of dust/dirt???
Any help would be appreciated.
Old Jul 9, 2003 | 03:05 PM
speed76demon's Avatar
I used just regular fuel injector cleaner worked fine for me.
Old Jul 9, 2003 | 03:07 PM
Blue96z28's Avatar
do you mean in the tank....because that not my question....
or do you mean that you used it as a solvent and physically clean the TB with it? Anyone else?
Old Jul 9, 2003 | 05:13 PM
BUBBA's Avatar
Tune-up/injector cleaner diluted with gas 1:4 or 1:5. Or just get a professional cleaning kit,e.g. www.intakesnake.com.
Carb cleaner or straight injector cleaner may be too strong unless mixed with gas. These hints taken from Car Care tips, Popular Mechanics. FWIW.
Old Jul 9, 2003 | 05:18 PM
MJ_Z28's Avatar
you can get "deep creep" TB cleaner...open the TB blades and spray it in there. While you're at it, get some Seafoam and follow these intructions: http://www.acaenterprises.com/camaro...m/seafoam.html
Good Luck!
wade
Old Jul 9, 2003 | 07:30 PM
Blue96z28's Avatar
Is the TB gasket safe to reuse for sure?????...I've heard both ways. How much is it if i were to replace it?
Old Jul 9, 2003 | 07:37 PM
If it is not torn, it would be ok. A new one is a couple bucks, though. Use cleaner that is O2 safe.
Old Jul 9, 2003 | 08:00 PM
pu12en12g's Avatar
Good Luck!
wade
FWIW, I did this and blew my headgasket the same day.
Old Jul 9, 2003 | 08:10 PM
MJ_Z28's Avatar
interesting...don't mean to hijack the thread...but is this common?
Thanks,
Wade
Old Jul 10, 2003 | 02:07 PM
pu12en12g's Avatar
Thanks,
Wade
I hope not... it ruined my entire summer.
Anon
Jul 23, 2015 12:18 PM
Boss002
Jul 9, 2015 03:33 PM
NewsBot
Jun 24, 2015 07:50 AM
Fatdog2
Feb 13, 2015 08:19 PM
jim6221
Jul 8, 2002 06:38 PM
