Which one first???
Old Feb 22, 2004 | 12:03 PM
LT1ponykilla's Avatar
Which one first???
Im about to get my heads ported and polished here pretty soon. I was told that my shorty BBK headers are probably choking my cam and I should get LT's especially if Im gonna do head work. So my question is with my mods and cam, should I get my heads done first and will my shorties be good enough for my setup or will I need LT's? Im also thinking about either running 2.5'' true duals or 4'' mufflex. Any advice would be appreciated!
Old Feb 22, 2004 | 12:18 PM
87transam383tpi's Avatar
i'd do the heads, the LT's will definately help but teh heads are going to help since you already have shorties. just my opinoin though
Josh
Old Feb 22, 2004 | 12:22 PM
stereomandan's Avatar
I would also do the heads. You can dyno afterwards and see if they are hurting you much. It's at the higher RPM's where you will see more of the negative affects of the shortes.
Dan
Old Feb 22, 2004 | 06:32 PM
I may save up and try to do heads and the LT's at the same time.
Should I go with true dual 2.5's or a 4'' mufflex? I dont think the single 3'' will give me all I could get from that setup.
Old Feb 22, 2004 | 11:15 PM
slashz28's Avatar
im no "pro", but the 3" should be enough for your setup. instead of spending the $$ on a 4" or true duals , buy the lt's
Old Feb 22, 2004 | 11:27 PM
Do you guys think the shorties will be fine even with ported heads and my cam???
Old Feb 23, 2004 | 12:14 AM
chesee48's Avatar
yea i think you'll be ok...
altho you already know that LT's are better, but shorties are still a decent option to go with IMO
Old Feb 23, 2004 | 09:04 AM
Thanks man.
Old Feb 23, 2004 | 10:12 AM
Camaro_Guru16NY's Avatar
Definately get the heads done instead but if you can get the Lts on as well they wont hurt you as much cuz shorties will get you by but Lts will help you even more,
later,
-JOhn
Old Feb 23, 2004 | 12:44 PM
Red96Lt1's Avatar
Like everyone already said, heads first. You should be ok with shorties for now.
Old Feb 23, 2004 | 12:51 PM
IDOXLR8's Avatar
Another vote for ported heads.
