old style 350 head gasket on an lt1?
Old May 9, 2004 | 09:33 PM
old93z's Avatar
What is the difference (other than a slight mismatch at the water jackets that i saw and maybe the gasket thickness) Is there anything major? The place i got the gaskets from gave me the gaskets, just wondering if they'd work
Old May 9, 2004 | 09:35 PM
Dave88LX's Avatar
Get the right gaskets.
Old May 9, 2004 | 09:41 PM
CANTONRACER's Avatar
I run old style head gaskets on my combos...but I would just get the right gaskets.
Old May 9, 2004 | 10:14 PM
Dave88LX's Avatar
Now I'm curious, why do you run the old-style gaskets?
Old May 9, 2004 | 10:17 PM
RedHottG2's Avatar
Would these still allow for reverse flow cooling
Old May 10, 2004 | 05:23 AM
I run very thin head gaskets.
You have to open up certain areas of them to make the flow properly.
Old May 10, 2004 | 09:31 AM
old93z's Avatar
Is the top corners (for the water passage) the only place ya opened them up?
Thanks for the replys.
The gaskets are already on and the engine together is why i hate to take it back apart and put the correct gaskets on if the only diference is the holes i cut out.
Old May 10, 2004 | 09:41 AM
That is all I ever done is the holes for the coolant flow.
Never had a problem.
Old May 11, 2004 | 08:48 AM
old93z's Avatar
Thumbs up
Thanks for the help CANTONRACER
Old May 11, 2004 | 09:32 AM
WS Sick's Avatar
Does this mean it is possible to simply modify a set of traditinal SBC copper head gaskets to fit?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
