OK what year is my engine?
Old Aug 6, 2007 | 05:47 PM
drptop70ss's Avatar
I have a 94z28 with a no start condition, so I have been going through the troubleshooting charts. I removed the harness from the opti and the connector was cracked, so I checked ebay to buy a new one. My opti uses the harness with the long flat connector which is shown to be 1995-1997, the earlier ones look different than what I have. So either someone converted to the later opti or the engine has been changed. Any way I can check to see what exactly has been changed? FWIW it looks like my optical sensor is dead so I will need another opti, good thing I didnt buy one ahead of time for the 94.
Old Aug 6, 2007 | 06:55 PM
bmwmcars's Avatar
do you have any pics of the connectors? might help id things.
Old Aug 6, 2007 | 07:23 PM
drptop70ss's Avatar
I got this picture from ebay, the long flat connector is what my opti uses which is described as a 95-97 style. When I looked up the 93-94 style they showed a more common looking connector similar to the ones seen on the engine on different snesors.
Old Aug 6, 2007 | 07:37 PM
lethal93ta's Avatar
someone swapped out the opti or maybe even the hole engine at one time, a 94 should have the other style.
Old Aug 6, 2007 | 07:41 PM
er-z's Avatar
http://shbox.com/1/block_vin.jpg check to see if your cars vin matches blocks vin
Old Aug 6, 2007 | 07:43 PM
drptop70ss's Avatar
Thats what I figured. I am going to get the opti off to confirm, but is there a casting date somewhere easy to see so I can check the block date? Any differences between 94-95 engines other than the opti and related parts up front?
Thanks for the pic, I will check the vin.
Old Aug 6, 2007 | 08:02 PM
bmwmcars's Avatar
one more thing to check out when the opti is removed is the cam dowel and the backside of the opti.
Old Aug 6, 2007 | 08:09 PM
lethal93ta's Avatar
the engine would have to have a diffrent cam in there other than a stock 94 cam as well, since the 94 cam dont have the hole in the center to line the opti up.
Old Aug 6, 2007 | 09:16 PM
drptop70ss's Avatar
Just pulled the opti, definately a later 95 up vented unit with the corresponding timing cover and cam. The opti is supposed to be only 6 months old, but following the diagnostics I have found here show a bad optical sensor. The water pump shows rust stains all around the bearing, looks like it may have leaked and killed the opti. I removed the cap and did find some moisture, other than that it looked new. What size torx bolts hold on the rotor? I didnt have one small enough to remove it, I want to pull the cover and look at the optical sensor. Any way to test it, maybe with a diode test setting on a DVM?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
