ok to use washers on rocker studs
Old Jul 13, 2008 | 12:41 PM
Blownbird355's Avatar
I'm installing 7/16 studs and nsa rockers. Is it ok to use washers on top of the guide plates if not threads are to long on studs.
Old Jul 13, 2008 | 12:46 PM
cnorton's Avatar
Are you referring to the threads on the part of the stud that goes into the head? Is the stud bottoming out on the tang at the bottom of the helicoil inside the head boss?
Old Jul 13, 2008 | 09:25 PM
yes bottoming out in head.
Old Jul 13, 2008 | 09:39 PM
LearJet's Avatar
What kind of studs/heads/guideplates? They shouldn't be bottoming out. Putting washers under them will probably cause problems with the hex on the stud interferring with the rocker arms. Make sure you are using the correct parts.
Old Jul 13, 2008 | 10:43 PM
cnorton's Avatar
LearJet is correct. Something is not right with the combination. ARP studs screw into LT1 heads with no problem.
Old Jul 13, 2008 | 11:49 PM
kylersaulsbury's Avatar
yep deff. an issue there.
should fit fine with or without guideplates.
Old Jul 14, 2008 | 07:01 AM
Thought I read it could be done and I started thinking about it and thought it would throw geom of. stock heads with cc 4501 studs with the GM guideplates.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
