OK guys, what is the best carrier to run in a 10 bolt ???
Old May 18, 2003 | 08:31 PM
chuckys95's Avatar
what is the best carrier i should run in a stock 10 bolt housing?
picked up a rear from a 2000 t/a and i am going to totally go thru it and replace everything i possibly can, and also have the complete housing powdercoated.....
just need a little input on the brand carrier i should go with.
thanks
Old May 18, 2003 | 09:03 PM
danner's Avatar
eatone 3-series with 4.10's for two years with no problem
Old May 18, 2003 | 09:43 PM
95 Z/28 LT1's Avatar
Super Moderator
The Torsen T2R is the best posi carrier on the market for the 10 bolt.
Old May 18, 2003 | 09:45 PM
Larnach's Avatar
What he said.
Old May 18, 2003 | 09:57 PM
norcalstreet's Avatar
Why throw all this money into a 10-bolt though? How much is this going to cost you for the parts, powder coating and assembly?
Old May 18, 2003 | 10:22 PM
djk19's Avatar
I have gone through this over and over and over.
When I purchased my 95 Z-28 from my friend he mentioned somthing about the differential being bad. I didn't get the one wheel peel much but somewhat (one tire worn a lot more too) So I started thinking of solutions.
I then bent and axle and decided it was time to get the job done. To get two high performance axles it is $300 then a high performance series 3 Carrier is $300-$500. That is $800. NOw it is time for the gears and install kit. Another $300. Then the install. $150. That puts you up over $1000 and probably closer to $1300 or so even if you buy all your parts at absolute bottom prices. Add a T/A Girdle? $150.00
If you do the math is is cheaper to get a ford 9 inch housing complete with axles and all the goodies. (most can be made to accomodate traction control too!) rather then have your flimsy never see upwards of 400 RWHP 10 bolt setup.
Since I am not planning on power adders I found a deal for $450 for a series 3 replacement posi unit, 3.73 gears and bearings, one oem new axle and a T/A cover.
Thank you tbyrne
Old May 18, 2003 | 10:30 PM
Larnach's Avatar
Screw powdercoating... degrease it and POR-15 that baby.
Old May 18, 2003 | 10:35 PM
djk19's Avatar
Is pore 15 that stuff that makes it look all dry but corrosion free?
Old May 18, 2003 | 10:47 PM
Larnach's Avatar
Paint Over Rust, its a great product, tough as nails, comes in like Flat Black, Gloss Black, Silver, and Grey... I'm using it when I rebuild my 10 bolt.
Old May 19, 2003 | 12:06 AM
96LT14u2Nv's Avatar
the diff out of that 2000 TA is a very good one. weld the axle tubes with that diff and u will be fine into the low 12's....trust me. dont throw away your money. they also sell take-outs at www.slponline.com for like $100
Old May 19, 2003 | 12:13 AM
Larnach's Avatar
The takeouts are on backorder.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
Cam's maro
Jan 8, 2015 05:01 AM
nballisru
Dec 14, 2014 05:01 PM
Red97LT1
Aug 7, 2002 05:45 PM
