ok to grind down dowel pin on cam???
Old Apr 12, 2003 | 07:29 PM
1995redZ28's Avatar
im in the middle of my hotcam install now. the old cam is out, and i am ready to install the new. i knew i had to shorten the dowel because i am sticking with my 94 opti style. my question is.... does the dowel have to be perfectly shaped?? i know the one from the factories is perfectly round. the new dowel also did NOT fit in the gear. so i ended up grinding down the sides in order for it to fit. is this ok?? i want to make sure i didnt mess anything up before i install it and put it back together! i would appreciate any help ASAP!!!! thanks a bunch!
Old Apr 12, 2003 | 09:02 PM
Josh-'04 GTO's Avatar
I believe the dowel should be the same except for being a bit longer. I would measure the dowel pin on the stock cam and cut down the Hot Cam dowel to match.
Old Apr 12, 2003 | 09:12 PM
96z's Avatar
96z
If I remember correctly it needs to be .620" long.
Old Apr 13, 2003 | 07:11 AM
Don 97 SS's Avatar
Referencing OBDII optis, GM states the dowel is to be "extended .620" from end of camshaft" (2003 GMPP catalog pg. 80).
Referencing Dynatech opti install tech data "the drive dowel OD: .250" max"
I hope this info helps with your application.
As an additional comment, I just installed a DynaSpark opti and a new Comp Cam in my 97. DynaTech recommends that the dowel be no more than .605" so I ground down the long dowel on the cam to those measurements.
Old Apr 13, 2003 | 08:57 AM
Smokn '94 Z's Avatar
Question Re: ok to grind down dowel pin on cam???
So when you say it did NOT fit you mean diameter wise? I was able to tap my pin in more to match the length of the stocker.
Noenav
Mar 1, 2019 07:38 AM
BPS
9
Mar 5, 2015 10:51 PM
willie-d-nice
Feb 13, 2015 06:40 AM
Cam's maro
Jan 30, 2015 09:21 PM
sscott
Jan 17, 2015 04:30 PM
