OK... fans wont come in
Old Oct 2, 2004 | 04:57 PM
budvol's Avatar
Now what?
Fuse is not blown... How do u check the relay? Also does it have a sensor and if so where is it?
What are the chances of both being bad since nether one will came on.
Old Oct 2, 2004 | 05:25 PM
JB94's Avatar
Re: OK... fans wont come in
I do know that you can check fan operation on a 94 by grounding the diagnostic port when using the ses light to check for trouble codes.when this is done and the key turned on both fans should come on, not sure about later models. Hope this helps.
Old Oct 2, 2004 | 05:33 PM
Z95m6's Avatar
if you wanted to test the fan motors you could unplug your maf and start the car this will set off an SES that will cause the fans to come on. If they don't come on then i would think the fan motors would be shot. If they don't come on then i would unplug one of the plugs and see if its getting juice.
Old Oct 2, 2004 | 05:45 PM
Turn on your a/c and see if the fans come on.
Old Oct 2, 2004 | 06:01 PM
budvol's Avatar
Turned on A/C one fan came on
Old Oct 2, 2004 | 06:06 PM
Ryan's LT1's Avatar
You just installed the a 160 Thermo right? The fans aren't programmed to come on until something like 220* and with your 160* it will take it some time to get that hot. You need to get a hold of a power programmer or send your PCM in for a tune that will make the low fans turn on at 180 and the highs at 190. The fact that your High came on when you turned the AC on is a good sign.
Old Oct 2, 2004 | 06:11 PM
budvol's Avatar
I havent got the 160 yet.
My overheat light comes on then before the fan are to kick in.
The light comes on about 190 or 200 is that normal?
Old Oct 2, 2004 | 07:57 PM
Ryan's LT1's Avatar
Do you mean the Check Guages light? That shouldn't come on until you're in the red, somewhere around 240-260.
Old Oct 2, 2004 | 08:58 PM
ShawnMacAnanny's Avatar
First fan kicks on right at the 210/half way mark. My car has never gone above this. Are you sure it isnt just waiting that long to kick on?
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
