Ok, did a search, still confused...
Originally posted by anaik
I would think the bottom line is the out, but not absolute on that.
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i assumed the bottem line was the return one as well.... but somebody.... i *think* shoebox.... told me it was the other way around...
ARGH I HATE CARS!!!!
well it matters for when i go to put in my directional filter.... it has to go on the return line....
anyone else know for sure which one the return line is?
Directional filter? Where'd you get that from?
Edit: if you want to know which is the return line you could take that line loose, start the car and see which side fluid squirts out of, the one that doesn't squirt will be the return line
Top line is return line
Take top line (return line) off of radiator, cut crimped rubber crap off with tubing cutter, replace top line which will now be shorter, you will then hook up your top line on the cooler to the top line on the radiator, bottom cooler line hooks up to only open line you have left, which the rubber hose you cut off is hooked too with a clamp.
This is so damn simple.
Top hose from radiator into cooler, bottom cooler hose into the hard line that was hooked to the top radiator line.
I do agree that the top line is the return line.
Damn, you started a novel here...lets hope you never have to install headlight covers. Seriously though, is it that complex of a procedure? It seems just fabbing up some lines would be best. Reliable and the finished install looks good to, no? Am i wrong?
autoxr166
Sep 25, 2015 04:21 PM
alliance12364
Sep 17, 2015 08:43 AM
Sep 11, 2015 09:44 AM
