oil smell help
last night I cought a funny wiff of like a plastic burning smell in side my car... Then on the Ride home from my girlfriends house I was smelling burnt oil... The car was still performing well its just i was getting bad burnt oil smells?
Help please... Could it be intake manifold leak??
So.. no info other than a 'burnt oil smell'? You've got to get it up on jacks or ramps and have a look around. Feel behind the intake and see if there's any oil, check the valve covers, check something!
I am running Rich my exhaust tips one trip into town there pretty hazy looking (oil) I know I have an Exhaust leak right where the manofold meets the y-pipe before the o2 sensor.. I think My opti is going out too..
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
ok, wait a minute...
your optis going, you have oil in your exhaust, you have an exhuast leak, you smell burnt oil, but you also smell gas, your running rich, your o2 sensor is probably going too...
my moms an alcoholic, my brothers queer, the draft ruined my chances of becoming a brain surgeon...
jesus dude... set a match to the car and don't look back is my advice...
My car smelled like that when my EGR valve was leaking. It would suck in the fumes through the heater vents into the car. Once I replaced the valve, the smell dissapeared. Check to see if you have a code for the EGR valve.
