Oil pump pickup (milodon) installed height question..
Old May 14, 2006 | 12:36 AM
Javier97Z28's Avatar
Moderator
I've read varying #'s on pickup height.. anywhere from 1/4-1/2"?
Also, my milodon pickup tube has a little metal frame under the screen area that is probably 1/4" long. When setting height, am I measuring from the screen down? Or from the little frame down?
Old May 14, 2006 | 02:05 AM
1racerdude's Avatar
Re: Oil pump pickup (milodon) installed height question..
1/4" is too close. I set mine at 1/2" with a ball of clay on the pickup. If ya put it on the screen put some masking tape under it to keep the clay out of the screen when it compresses.
Measure to where 1/2" of liquid will come to the top of where the screen is attached to the metal. The screen at this point should not be touching the bottom of the pan.
The pickups I use the screen is at the bottom/end of the tube.
Like the stock one's are round with a metal cover half way over the bottom and a screen on the other half. I put the metal cover at 1/2" from the bottom and the screen is wherever it winds up.
Old May 14, 2006 | 08:13 AM
SStrokerAce's Avatar
Bah... I do it at 3/8th's lol
Follow racerduds advice.
Bret
Old May 14, 2006 | 08:27 AM
Moderator
K guys thanks
This is the pickup I have.. I like it since it has the bolt in bracket. I'll set it to 1/2" from the screen.
You guys rock, have I told you that lately?
Old May 16, 2006 | 09:51 PM
Moderator
I'm getting about .4" from the bottom of the pan with clay b/w the screen itself and the bottom of the pan... wheeee I still had more to go as far as tightening up the pan goes too... so it might even be like .3...
I'll try to move it upward some tomorrow.. I don't want to work on my car till 1am tonight..
Old May 16, 2006 | 10:01 PM
1racerdude's Avatar
Allow for the gasket.
Old May 16, 2006 | 10:31 PM
Moderator
That was with tthe gasket in... i wasn't compressing it down tho
Old May 16, 2006 | 10:56 PM
1racerdude's Avatar
Old May 17, 2006 | 06:23 AM
Jeff95TA's Avatar
I don't know...... I just set my Canton one at 13/32" instead of 3/8".
Old May 17, 2006 | 02:32 PM
1racerdude's Avatar
I have found that 27/64 works the best of all.
Old May 17, 2006 | 02:36 PM
Moderator
Quit making fun of me
Old May 17, 2006 | 02:40 PM
1racerdude's Avatar
I'm making fun of Jeff.
Old May 17, 2006 | 03:12 PM
Moderator
I thought Jeff was makin light of me
lol i don't care either way, just messin
Old May 17, 2006 | 03:36 PM
1racerdude's Avatar
Heeee Heeeee
Old May 17, 2006 | 10:37 PM
firebirdStud's Avatar
my canton ended up bein 9/16". I was a little worried, but the techs at work said it was fine. I can't adjust mine, there is no way. There is a bracket that attatches to the oil pump housing bolt. Works for me though...
