Oil pump install???????
Basically you just put the driveshaft and little retainer/collar on it to hold it on, align the slot in the shaft to the drive mechanism and bolt it on. Torque to 66 lb. ft.
If the drive oil pump cam drive is out, then you don't have to worry about aligning it.
Jul 4, 2005 05:00 PM
