oil psi ?
Old Dec 28, 2007 | 09:25 PM
93camarochrisz28's Avatar
Post oil psi ?
i just got the car running again (car in sig) and at idle my oil is at about 20 25ish is that ok for driving around
Old Dec 28, 2007 | 09:34 PM
dangalla's Avatar
that seems a little low, but not crucial. what oil are you running? did you just rebuild it or something, why did you say running again
Old Dec 28, 2007 | 09:53 PM
speed_demon24's Avatar
With my stock pump I was getting ~20 at hot idle and 35-40 cruising. With my new melling 15554 select pump I get ~35 at idle and ~50-55 cruising. If the 20-25 is at idle you should be fine.
Old Dec 28, 2007 | 10:50 PM
mrmint69's Avatar
When its warmed up i get 18 at idle. Sounds like its fine.
Old Dec 28, 2007 | 11:26 PM
i am useing 10 40 thats what i was told to used and it is on brack in and yes just rebuilt it so i dont want to f anything up
Old Dec 29, 2007 | 01:47 AM
96supersport's Avatar
There should be around 10 psi for every 1000 rpms.
ex: 1000 rpm = 10 psi
2000 rpm = 20 psi
and so on
Old Dec 29, 2007 | 07:06 AM
dangalla's Avatar
with a new motor you should really have a little more pressure than that, what oil pump and spring did you use, did you build it yourself or have someone else do it
Old Dec 29, 2007 | 07:23 AM
01Z's Avatar
01Z
If you are monitoring the pressure by the gauge in the dash, you may not be seeing the real pressure. Old pressure senders can be wrong.
Old Dec 29, 2007 | 07:28 AM
<Puck>'s Avatar
What rpm are you idling at? Seems a little bit low but nothing dangerous.
I hot idle at ~22 with 5-30 via an aftermarket electric gauge above my oil filter. Next oil change I am going up to 10-40 though.
With 20psi, as long as it rises with rpms from idle, you are fine.
Old Dec 29, 2007 | 08:24 AM
20-25 at hot idle is fine.
Old Dec 29, 2007 | 08:31 AM
i used a new stock oil pump and i rebuilt it my self and it is my frist motor i took my time so i think everything is ok but dont want anything to happen thats all
Old Dec 29, 2007 | 12:15 PM
Z28LT1_Just_Nasty's Avatar
At hot idle my car runs about 20 psi using mobil 1 5-30. You are probably fine.
Old Dec 29, 2007 | 12:18 PM
windsma's Avatar
My rebuild w/ new stock pump hit 70psi.
Old Dec 29, 2007 | 03:19 PM
Wild1's Avatar
My '69 starts at 60 psi cold then drops to 25 at idle when at normal operating temperature.
Old Dec 30, 2007 | 06:24 AM
regal502's Avatar
Take a look at Rob's (shbox.com) tech page. {http://shbox.com/1/engine_specs.jpg}
He's got the factory GM specs page on this page. Look at GM's specs on oil pressure-- you'll be shocked, but this should end all questions to what "should oil pressure be"
~Tom
And remember, NASCAR runs at 8,500rpms for 500 miles with 45 psi of oil pressure!
