oil pressure sensor
Old Sep 12, 2007 | 11:30 AM
Bails098's Avatar
oil pressure sensor
i have a new oil pressure gauge was wondering if there is an alternante spot i can put the sensor on my lt1
Old Sep 12, 2007 | 11:38 AM
It would be nice if we knew the year car you have. The sensor is not in the same place on all years.
These links will show you two places the sensor could go.
http://shbox.com/1/oil_pressure_sensor.jpg
http://shbox.com/1/aux_oil_port.jpg
Old Sep 12, 2007 | 11:39 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
There is a plug right above the oil filter/oil cooler that you should be able to use. I guess you would have to run the wire down there. I attached a mechanical gauge in that location last week.
And that's assuming your existing sensor is mounted on the rear of the block behind the intake manifold.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
