Oil pressure sending unit, uses one connector... but!
Old Jul 9, 2003 | 03:09 PM
DR.ZED's Avatar
There are three terminals on the unit itself, yet the connection for the gauge cluster has on wire.
This tells me, that this sensor is the same one as in the Vette, which shows oil TEMPERATURE.
I wonder if we can rig an electronic gauge to this?
Any thoughts?
Old Jul 9, 2003 | 03:32 PM
Dave Feerst's Avatar
Mabye if you got the gauges out of a vette and made your own wires it would work, If anyone has done this I'd like to know.
Old Jul 9, 2003 | 04:21 PM
It probably also is the same one that utilizes a fuel relay shutoff too, but since our harness has only one wire to it, that function can't really happen. So is it for oil temp or fuel pump shut off (or both)?
Old Jul 9, 2003 | 04:46 PM
are you saying that the gauge has to run through the ECM to be functional? I would think if it is a 2 wire gauge it would be as easy as routing the 2 wires from the gauge to the connector and using pins from the delphi kit to make it a 3 wire connector, or mabye purchasing the corvette connector and pigtail from a junkyard.
Old Jul 9, 2003 | 04:54 PM
I'm saying that the one wire runs from the sensor to the gauge and nowhere else. All it can do is report oil pressure.
Old Jul 9, 2003 | 06:22 PM
Mtrhds94Z's Avatar
Is there a 'low oil fuel shutoff' on these cars?
The question arose the other day, and I tend to think NO, but haven't had time to look it up yet?
Old Jul 9, 2003 | 06:35 PM
InjectedSS's Avatar
nope there isnt! but it would be nice if there was!
seriously why didnt we get that setup like the stupid vettes are more important than f-bodys
Old Jul 9, 2003 | 07:15 PM
Charlie, you might find mention of it in the manual, but since we only have the one wire to the gauge, it isn't going to happen.
Old Jul 10, 2003 | 06:28 AM
Mtrhds94Z's Avatar
Thanks!
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
