Oil Pressure sender on a 93
Old Apr 4, 2007 | 10:54 PM
Finchinater's Avatar
I know mine is by the filter as opposed to on the intake, but could this be a source of an oil leak? Can I tighten it up or just replace it?
Thanx masters.
Later hosen,
Finchy Fo Bob
Old Apr 4, 2007 | 10:58 PM
Yes, yes and yes.
Old Apr 4, 2007 | 11:02 PM
Jared 3870's Avatar
You can also bust it off during a header install, then tighten the new one up to stop the leak.
Old Apr 5, 2007 | 09:35 AM
OBE1 95Z28's Avatar
This sounds like a good plan It's a pipe fitting thread so you can try tightening it or you can remove the sensor and apply a small amount of teflon sealant to the threads.
Old Apr 5, 2007 | 09:37 AM
DirtyDan's Avatar
Use about 2 wraps of teflon tape on it and re-install it. Never had a leak on my 93 doing it this way.
Old Apr 5, 2007 | 11:00 AM
Teflon tape can be dissolved by the oil. Thread sealant is a better choice, IMHO.
Old Apr 5, 2007 | 11:09 AM
Jared 3870's Avatar
Plus if you get a little too much tape on the threads you will have a hard time getting it to thread.
+1 thread sealer.
Old Apr 5, 2007 | 10:29 PM
Thank you all. I will try the thread sealer in the short term, cuz longtubes are gonna be installed as soon as work settles down.
Thanks again,
Finch
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
KYWes
Apr 15, 2015 05:48 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
