oil pressure question
Old Sep 4, 2007 | 05:59 PM
football4life's Avatar
i have a 95z and i was driving this weekend and lately it seems to be lacking power well i was watching my oil pressure gauge and when im cruzing at about 55-70 i press the gas and the pressure goes down a little below half but i let off the gas and the oil pressure goes up above half a bit i was wondering if this is a problem and how can i fix it .
thanks josh
Old Sep 4, 2007 | 07:29 PM
seawolf06's Avatar
Are you in an auto? Does it bog when you press the gas or rev up? If it's dropping when you rev it up then you have a problem. It should increase as the RPM increase about 10 psi for every 1k RPM.
Old Sep 4, 2007 | 09:26 PM
yes it is auto and it starts to drop when i hit about 45 in 5 gear i will have the rpms about 1900 and the oil pressure is higher than when i go to 2200 rpm then if i let off or go higher rmp the oil pressure goes up. just by guessing i would say that the pressure drops maybe 5-10psi
Old Sep 4, 2007 | 09:35 PM
johnnyb's Avatar
maybe a vacum leak would have something to do with it? just a theory that makes sense in my head but maybe has nothing to do with it
Old Sep 4, 2007 | 10:23 PM
belac350's Avatar
Any good answer on this, as I have the same problem. It seems to only happen with high engine load, high gear (M6) and low rpms. Only thing is my power feels good. I was going to put a mechincal gauge on to see if what its really doing.
Old Sep 5, 2007 | 01:59 PM
That what is happing to mine i will look at the vacuum tonight to c if anything is leaking
Old Sep 5, 2007 | 06:03 PM
belac350's Avatar
Do you have any major mods? I was going to check the rocker settings, change the oil and filter, cut the old one open and check it.
Old Sep 5, 2007 | 07:19 PM
Danny McAdams's Avatar
I have found that when the oil pressure drops on acceleration most of the time it is a sign of main bearing trouble, especially if it drops as much as you state and then returns. I would be sure the oil is at a correct level and gauge is correct first. Danny Mc
Old Sep 5, 2007 | 08:03 PM
seawolf06's Avatar
That's what I would think as well.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
