Oil pressure problem
Old May 27, 2007 | 12:05 AM
gr8cars1's Avatar
Angry Oil pressure problem
I was wondering if anyone could help me with this? I have a '94 Camaro Z28 with the LT1 motor. My oil pressure measures between 40 & 45 psi while driving but drops to just below 20 psi when at idle. I just had the car in the shop where we replaced the water pump and a couple of sensors. The technician drove it after the install and said my oil pressure was functioning normally. Is ti just me or does this much fluctuation seem excessive? What should it read?
Old May 27, 2007 | 02:13 AM
Nitelite's Avatar
I'd say its normal. If it bugs you too much, just put some thicker oil in it, would probably make it hold higher pressure at idle.
Old May 27, 2007 | 03:53 AM
TwEaKeDSS's Avatar
Try hooking up a different oil pressure gauge. The stock gauge is pretty crappy.
Old May 27, 2007 | 07:58 AM
Sounds normal to me.
Old May 27, 2007 | 08:43 AM
wrd1972's Avatar
Normal enough.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
