oil pressure problem
Old Jul 17, 2004 | 06:51 PM
david97gsxr's Avatar
recently i noticed my oil pressure is staying at around 40-42 at WOT.
when i first start the car, if i start cruising and give it a little extra gas the oil pressure will go up to around 60ish. but after the car's warm it'll stay around 40.
at idle it's around 18-22. and cruising it's at 40ish.
even in neutral if i rev it up it stays at 40-42. the only way i could get it to go above that was to put it in first gear, and accelerate and hold it at about 5000 rpm, after about 2-3 seconds the oil pressure shot up to 60-65.
i just recenlty changed my oil but i used the same kinda oil, same viscocity(sp?) and filter as i always do. and the oil level is fine as well.
any thoughts?
Old Jul 17, 2004 | 07:18 PM
96capricemgr's Avatar
What are you using? Also consider that OEM dsh gauges are not great.
Old Jul 18, 2004 | 06:49 PM
Re: oil pressure problem
i'm using castrol 5w30.....it's what i always use.
but today i monitored it, and it was working fine on my lunch break, but on the way home it was doing that crap again....i dunno.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
