CamaroZ28.Com Message Board
-   -   Oil pressure normal operating range? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/oil-pressure-normal-operating-range-523321/)
always faster May 27, 2007 02:30 PM
Will im searching for my other problem i realise that my oil pressure is really high on my gauge(stock one).
When i start it,i get around 412 wich is excatly in the middle between the 275mark and the 550 mark
When it get worm the oil pressure would stay around 275 right in the middle of the gauge.
My last motor never reach those number.
Right now im running some 5w30 castrol mineral oil for my break in.I also got a new sending unit.
Is it good or bad ?
1racerdude May 27, 2007 03:13 PM
Oil pressure on a stock one should be between 0-50PSI.
On a built engine it is whatever ya set it at but NOT 275PSI.
always faster May 27, 2007 03:31 PM
Is the stock gauge graduate in psi? Man im runnig right between the 275 mark and the 550 mark.It seem impossible :confused:
1racerdude May 27, 2007 06:05 PM
Should be in PSI.
always faster May 28, 2007 07:12 AM
How the hell could the stock gauge be in psi.Normal people got around 60 psi when its cold and around 20psi when its hot.
If the stock gauge is in psi i would have over 275 psi off oil pressure in my motor...That doesnt make sens:o
mdacton May 28, 2007 07:33 AM
are you sure its in PSI.....not kpa or something like that? You close to canada?
always faster May 28, 2007 07:41 AM
Exactly was i was trying to say in my bad english(sorry).The stock gauge is graduate like this= 0(start)-275(middle)-550(end)
There is no way that i would have over 400psi of oil pressure in my car ;)
Yeah im from Quebec,Canada
mdacton May 28, 2007 07:47 AM
I would say your goood then....about half way. seems o.k.
maybe find a conversion chart......rule of thumb is 10 psi per thousand rpm's
6000 rpm= 60psi
hope that helps, Good day canadian
always faster May 28, 2007 07:51 AM
6000 rpm= 60psi
Yeah i just found a pictures of a US cluster and yours are already graduate in psi,lucky for you ;) : (start)0-(middle)40-(end)80
So mine is in KPA.
10 KPA = 1.4503773773020922 PSI
So when cold my 412 KPA = 59.7555479448462 PSI
And when hot my 275KPA = 39.885377875807535 PSI
So my car is perfect.
Thank you for you help :bow:
aboatguy May 28, 2007 07:52 AM
PSI = 0.145038 X kPa
Looks like he's good
412kPa is 59.755656
275kPa is 39.88545
aboatguy May 28, 2007 07:58 AM
Dayumm beat by a minute
always faster May 28, 2007 07:59 AM
Lol thanks for double checking my numbers.
Look like my oil pressure is good :thumb:
