oil pressure issue
Old Jan 29, 2014 | 07:11 PM
Brandon Wittmer's Avatar
oil pressure issue
I am having very very low oil pressure at idle. I bought the car about 2 months ago and when I first got it was fine but now as I drive it more the oil pressure is dropping at idle to the point where i had to put engine honey in it to pull it back up it went down to 0 at idle the other day but when i rev motor jumps way back up so i don't think its the pump more thinking cam bearings. so i am planning engine rebuild but wondering can cam bearings be replaced in car? not thinking they can.
Old Jan 29, 2014 | 09:36 PM
Re: oil pressure issue
You cannot replace all cam bearings in the car. I would try to verify your pressure with a mechanical gauge. Your o/p sensor might just be bad.
Old Jan 30, 2014 | 11:50 PM
Zeke28's Avatar
I had the same problem with my 94 Z. Replaced the AC Delco oil filter with a K&N. The problem went away and has been fine ever since. The AC filter probably collapsed.
HectorM52
Jul 30, 2017 11:46 AM
Cam's maro
Mar 24, 2015 08:09 PM
transam_388
Mar 15, 2015 11:53 AM
Z28countrymama
Jan 22, 2015 02:50 AM
Jessie4tin
Jan 7, 2015 08:53 AM
