Oil pressure issue
Old Jun 21, 2007 | 10:42 AM
  #16
Wild1's Avatar
Yep, they have an oil pump. But you might want to see if anyone has an oil cooler for '97. Or, you can peak under your car to see if you have 2 hoses going to the fixture above the oil filter.
Curious, are you using Quaker State?
Old Jun 21, 2007 | 12:43 PM
  #17
96z28t56's Avatar
95 was the last year that it was avliable, it's easy to see if you have one, and it's also possible that someone put one on it. Im putting one on my 96 when i rebuild my motor.
Old Jun 21, 2007 | 10:32 PM
  #18
JP95ZM6's Avatar
Originally Posted by Irocdriver89
First i want to say thanks for taking the time to right the article.
But that bought about another question you said i need to drain the oil or the coolant before i clean the oil cooler up. also if i were to remove the unit what would i need to replace it with! an as i think about it, i had the valve cover off not to long ago. cleaning around the edges and some did get into the motor! and that might be whats stuck in the oil cooler way. Thanks i will be working on this for sure this week!
You actually don't NEED to drain the coolant either, you can just clamp the hoses off gently so they don't leak, if you have something appropriate that won't hurt the hose. Just don't pinch it with plain vice grips or anything that will over-crush the hose, or you will get a weak spot. Oil doesn't need to be drained.
I don't know if any 97's have these coolers, either. Please let us know if yours does. It looks like this, Courtesy of Shoebox:
http://shbox.com/1/oil_cooler.jpg
HectorM52
Jul 30, 2017 11:46 AM
Cam's maro
Mar 24, 2015 08:09 PM
transam_388
Mar 15, 2015 11:53 AM
Z28countrymama
Jan 22, 2015 02:50 AM
Jessie4tin
Jan 7, 2015 08:53 AM
