Oil pressure gauge... Problem
Old Mar 13, 2005 | 09:12 AM
blacknwhite95Z's Avatar
I recently changed out the gaskets in my engine when I put it back together the car runs, BUT
the oil guage in my dash reads off of the gauge.
It points straight up past the numbers.
Any ideas why this is happening???
Old Mar 13, 2005 | 09:17 AM
Dave89IROC's Avatar
Re: Oil pressure gauge... Problem
is the sender pluged in?
Old Mar 13, 2005 | 09:19 AM
JB94's Avatar
It sounds to me like you may have pinched the wires to your sending unit.Grounding this circuit will make your gauge read full scale.Trace the wires back from the sending unit and make sure the wires did not get pinched under the intake manifold or valve cover.
Old Mar 13, 2005 | 09:39 AM
I hate to ask this but...
Sender unit? where is this located at?
I TRIED TO MAKE IT A POINT TO LEARN THE NAMES OF EVERYTHING i TOUCHED UNDER THE HOOD. Because I am not that experienced and I do not know where the sender unit is.
Old Mar 13, 2005 | 12:02 PM
CamaroBoy96Z28's Avatar
The oil pressure sending unit is directly behind the intake manifold on the driver's side of the engine by the firewall on an angle fitting.
Old Mar 13, 2005 | 12:45 PM
SWEET... I got it.
I did not plug it back in.DUH
Thanks guys.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
