oil pressure drops really low when car warms up
Old Aug 17, 2007 | 07:26 AM
pa97z28's Avatar
When the car is cold it starts right up and idles fine it has a LT4 conversion. When the car warms up it won't idles it stalls if you don't keep giving it gas the oil pressure drops real low.
thanks for any help you can give me in advance
Old Aug 17, 2007 | 09:00 AM
96z28t56's Avatar
What PSI is it dropping too?
Old Aug 17, 2007 | 09:55 AM
pa97z28's Avatar
down to zero and it stalls
Old Aug 17, 2007 | 10:41 AM
White96Z28's Avatar
Drops to zero and then stalls or stalls and then drops to zero? I know it's a trivial question, but that's kinda important. Keep in mind that once the idle drops down to a certain point, the oil pump is turning so slowly that it can't keep the pressure up. I would be willing to bet that if you can get the car to idle, you won't have the pressure problem. Try unplugging your MAF and see if it will idle.
Old Aug 17, 2007 | 10:52 AM
Z-RATED94's Avatar
Don't worry about the oil pressure until the car idles right. Was the oil pressure ok when it did idle right?
Old Aug 17, 2007 | 10:55 AM
johnnyb's Avatar
i installed my hotcam kit over winter and had the exact same problem you are... i spun a bearing
Old Aug 17, 2007 | 11:20 AM
pa97z28's Avatar
but it runs just fine until it warms up idles perfect would it do this with a spun bearing and if so how much did it cost to get that fixed
Old Aug 17, 2007 | 11:25 AM
Jazsun's Avatar
Your talking a rebuild. I'd say around $1500-$2000
Old Aug 17, 2007 | 11:40 AM
CheshireCat's Avatar
After you installed the HotCam kit, did you get a tune? If not, it could be accounting for your idle problems in closed loop. (engine warm). As stated by many above, if the car won't idle, then you won't get oil pressure.
Also note, that if you live in one of the many areas of the country that are getting high temps above 100* right now, then chances are your oil is running hotter than usual and that will account for some loss of oil pressure as the oil loses viscosity as it gets hotter.
Old Aug 17, 2007 | 11:44 AM
pa97z28's Avatar
no I had it tuned dynoed and the oil pressure drops all the way down then goes up a little and pretty much just bounces up a little and then back to zero very confussing
Old Aug 17, 2007 | 12:11 PM
White96Z28's Avatar
It sounds like normal fluctuation when your idle drops down that low. The oil pressure isn't a concern until you get the idle issue fixed.
97SSdude
Dec 31, 2014 07:43 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
