Oil pressure dropping under hard braking?
Old Sep 17, 2003 | 10:52 AM
Robs02RT's Avatar
Hey guys,
My oil pressure is dropping under hard braking. It will drop as the car is coming to a stop, stay at Zero( check gauges light comes on for a sec.) then jumps back up to normal once the car is settled and completely still. My car is a 96 WS6 6spd with 60k miles. It's running fine, oil pressure is fine under all conditions EXCEPT under hard braking. I checked the oil( mobil 1 5w30) and it looks fine. I change it every 3000 miles.
Soooo, I'm gonna change the oil and check the filter for contaminants. Any ideas what could be wrong?
I'm praying it's not a bearing
Any input is appreciated
Thanks,
Rob S.
Old Sep 17, 2003 | 11:01 AM
anaik's Avatar
Could be the oil pump pickup fell into the pan. When braking the oil would move forward letting the pump suck air. Drain the oil and rap on the bottom of the pan with a rubber or plastic hammer, to listen for the pickup to jump up and down. Or run a coat hanger thru the oil drain hole to see if you can feel anything in the pan.
Old Sep 17, 2003 | 11:30 AM
grygst76's Avatar
I agree, a loss in pressure when braking and then slow increase means the pickup is off or you have some serious low oil by about 3 quarts!!! you said your low oil light comes on?? Then you are low on oil!!!
Old Sep 17, 2003 | 03:26 PM
Robs02RT's Avatar
Thanks for the quick reply.
It's not low on oil so it must be the pickup.
Do I just drop the pan and reattach the pickup?
thanks,
Rob S.
Old Sep 17, 2003 | 03:50 PM
anaik's Avatar
thanks,
Rob S.
You should remove the oil pump and have the pickup tack welded to it, to prevent it from happening again. The factory just press fits it in.
Old Sep 17, 2003 | 11:32 PM
apick42's Avatar
please let me know what you find out about this because i
have had the same problem for some time. But a friend of mine
has a 94 z28 and his does the same thing.
Old Sep 17, 2003 | 11:44 PM
notstock4long's Avatar
I have a spare working pump and pickup if anyone needs it.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
