Oil pressure on cold start use to be 75psi.. Now its 60psi. Any ideas? White Spring
Old Aug 25, 2004 | 06:11 PM
ZDriver96's Avatar
Did a cold start up and it went up to 60psi... It use to go to 75psi.. I also unplugged the sensor to see if the gauge would shoot staight up and it did. Perhaps the gauge is reading incorrectly??
This is after my car almost stalling and dying after being run hard.. And when it went to idle at one point oil pressure went to 0. With the cold start up i changed the oil weight ot 10W40 from 10W30
The pick up is welded on. and I have a high pressure white spring too.. Brand new oil pump with 600 miles on it.
Old Aug 25, 2004 | 06:25 PM
xxsaint69x's Avatar
Re: Oil pressure on cold start use to be 75psi.. Now its 60psi. Any ideas? White Spring
i hope you arent using the stock guage..its pretty much useless.
Old Aug 25, 2004 | 06:53 PM
ZDriver96's Avatar
yeah i am using the stock gauge...
Could it be that its a brand new engine and after getting on it hard it ground away some of the rings edges.. so now it holds less pressure because it ground away some of the rings. I found some metal on my oil drain plug but after filtering it out with a coffee filter it looked normal for a new engine.
My idle still sucks though.. Idle sucking happened same time oil pressure was looking alittle low and dropping to 0 at that 1 point.
Old Aug 25, 2004 | 10:50 PM
Spinner's Avatar
Who cares? Both are well above what it SHOULD have, and you can't tell without a decent gauge anyway.
Old Aug 25, 2004 | 11:08 PM
DrewHMS97SS's Avatar
what oil filter are you running?
Old Aug 25, 2004 | 11:17 PM
SS MPSTR's Avatar
This makes a difference, as I learned tonight. K&N oil filters only, for me.
Old Aug 25, 2004 | 11:30 PM
k&n + 80 psi = oil on the ground and stop the car.
Old Aug 26, 2004 | 08:23 AM
ZDriver96's Avatar
was using purelator but i was at walmart and they didnt have purelator is i picked up a fram tough guard...
When it was at 75psi it was purlator
now its at 60 with the fram
I dont know if thats the reason or not??
Old Aug 26, 2004 | 10:36 AM
SS MPSTR's Avatar
My pressure went up slightly with the K&N over the NAPA filter, but not to 80 psi, and there's no oil on the ground.
Old Aug 26, 2004 | 11:25 AM
i think the filter can effect the psi a little, not sure about 15 though. was the purelator an o-ring style filter, or did it have the big thick rubber seal?
Old Aug 26, 2004 | 01:35 PM
izzyz28's Avatar
I have been running NAPA Gold filters on mine, and this last oil change I used a Fram because that's what I was able to get my hands on. Pressure dropped 5-7 PSI across the board with the FRAM, and I'm using an AutoMeter gauge. Do the Fram's filter better(I doubt it), or are they just more restrictive?
Old Aug 26, 2004 | 07:20 PM
i like k&n better than anything. my oil pump is just putting out too much
HectorM52
Jul 30, 2017 11:46 AM
Gtpguy
Jan 26, 2015 04:50 PM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
