Oil Pan part number?
Old Nov 26, 2005 | 01:52 PM
supercharged87's Avatar
What's the part # of the stock oil pan off a '94 Camaro? I have so much sludge built up in the baffled area of my stock oil pan from leaving it sit around, and I cleaned it about a 100 times and I can't get it out. I figured it would be so much easier to just buy a new one. Also what about a performance one? Any good ones out there for the LT1 that still keeps a litttle ground clearence? Thanks.
Old Nov 26, 2005 | 02:15 PM
SStrokerAce's Avatar
Re: Oil Pan part number?
The Canton Pan is a good choice for a aftermarket one.
Bret
Old Nov 26, 2005 | 02:22 PM
97WS6SCharged's Avatar
Bret
Yeah, mine's real perty with the gold pan and the red/blue oil fittings welded into it.
Old Nov 26, 2005 | 02:38 PM
I like them to match the motor, so I paint them black.... if I could host some shots I'd show ya
Bret
Old Nov 26, 2005 | 03:15 PM
I can put them into a webshots album along with the 18 degree brodix head pictures you sent me.
Old Nov 26, 2005 | 03:22 PM
Dave '97 Z28 M6's Avatar
It's # 12557557
Old Nov 26, 2005 | 03:27 PM
Chris, sent you one pic.
Old Nov 26, 2005 | 08:21 PM
A dip in a machine shop hot tank will clean it right up.
Old Nov 27, 2005 | 10:55 AM
I actually dropped my stock one off at the machine shop like you said shoebox. I actually bought a chrome aftermarket pan and the machine shop said that the chrome holds the heat in and he recommended me not using it. Does the gold zinc plated pan hold the heat also, I'm just wondering out of curiousity? Thanks you everyone for your replies.
Old Nov 27, 2005 | 03:54 PM
Hot oil is a good thing if you use synthetic oil. I would still rather use a baffled pan with a good windage setup over something with bling.
Bret
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
