oil pan help
Old Jul 20, 2006 | 05:24 PM
Daniel6718's Avatar
oil pan help
in response to seeing injuneer say that goerge and himself use the stock pan...i do to...but i have a problem with mine...in neutral i can slowly rev to 6000 and when it at 6000 its at 80 or so plus oil pressure...so0o0o i go out and hit a 20 roll and it drop to about 35 or so on the stock gauge and climbs to about 50. when i get to the next gear it drops again...i think its really almost no oil pressure at all...i think its all being pushed to the back of the pan...
also i used to rev in neutral and it would drop after 3000 i added half quart and now it goes to 80 plus...
so my specks are...tight rebuilt stock bottom end stock volume pump and pickup...valvoline 30 weight oil with a pf1218 truck filter...any help or anything else to try...is 6qts too much for a stock pan? i am about to try it...and yes my stock windage tray is in there but no baffles with the stock pan...is the fix to get some welded in? or simple as add oil?
how much is too much oil....
thanks in advance
daniel
Old Jul 21, 2006 | 12:16 AM
Daniel6718's Avatar
Re: oil pan help
nobody has anything to say...besides get a moroso or somethin with a baffle?
Old Jul 21, 2006 | 12:30 AM
CAMSS30's Avatar
Re: oil pan help
My brand new moroso 5.5qt pan with kickouts and traps leaks on the weld, they tell me to use their A@B apoxy to fix it and guess what it still leaks.
Old Jul 21, 2006 | 12:37 AM
Daniel6718's Avatar
Re: oil pan help
lol repost x5
Old Jul 21, 2006 | 12:47 AM
CAMSS30's Avatar
Re: oil pan help
fix't, board got real slow.
Old Jul 21, 2006 | 11:58 AM
Daniel6718's Avatar
Re: oil pan help
HELP...no1 modifies the pan?? injuneer goerge...yall have no baffles? just a completely stock pan?
Old Jul 22, 2006 | 01:00 AM
Daniel6718's Avatar
Re: oil pan help
nobody knows? then which aftermarket pan do i need? which ones best quality?
HectorM52
Jul 30, 2017 11:46 AM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
