Oil pan FYI...
Old Jun 13, 2007 | 01:17 AM
SS MPSTR's Avatar
Oil pan FYI...
If you guys get a Moroso #20185 oil pan for your LT1, just buy their recommended pump and pick-up tube. I got the 22111 pump and 24213 pick-up that is made specifically for their pan.
Ask me how I know other pumps/pick-ups don't fit
Old Jun 13, 2007 | 12:47 PM
seawolf06's Avatar
Does thier pump have a high volume or high pressure option? Is the pump pickup bolt on or just press in? Is it a melling casting and if so, is it a thick or thin casting?
Why won't the other pumps work? Thanks for the info, btw!
Old Jun 13, 2007 | 01:05 PM
SS MPSTR's Avatar
The pick-up is a press in (can be tacked on as long as you do not overheat one side), it is a Moroso thick casting (don't know if Melling makes it or not - I'll post back up when it arrives tomorrow), and it is available in a HV configuration. The pick-ups are different for the stock volume and HV pumps.
The other pumps don't work as the pick-up and pump won't sit properly - the pick-up looks like it is reversed
Old Jun 13, 2007 | 06:13 PM
seawolf06's Avatar
Crazy! Let us know when you get it done, and some pics would be awesome. Thanks!
Has anyone had the same problem with Canton pans?
Old Jun 13, 2007 | 08:50 PM
tireburnin's Avatar
Mike,
You've done enough "learning" the hard way. Hope it all goes smoothly and gets back on the road soon.
Old Jun 13, 2007 | 10:37 PM
SS MPSTR's Avatar
Originally Posted by tireburnin
Mike,
True enough. You'd think a reputable shop would know you can't heat up a cast piece of metal (i.e. pump) and expect it not to warp. The oil pump was freakin' ruined, and likely sucked a lot of air at WOT conributing to the demise of the bearings. Still, 120mph ain't bad for an engine built as poorly as mine was - it had to be in the cam and heads
Old Jun 13, 2007 | 11:03 PM
blown383's Avatar
Its the same with the Canton Pans....you need their special pick up depending on the diameter of the inlet on the oil pump. Speaking of which I have an extra Canton pick up and matching Melling HV oil pump for sale.
-B
Old Jun 14, 2007 | 09:34 PM
SS MPSTR's Avatar
After reciept today, it is a Melling thick cast pump.
Old Jun 15, 2007 | 01:14 AM
seawolf06's Avatar
And it's not a bolt on pickup? Interesting...
Old Jun 15, 2007 | 02:28 AM
blown383's Avatar
Not all pick ups are bolt on....however the canton pick ups utilized for their pans with the Melling pumps are all bolt on.
-B
Old Jun 15, 2007 | 05:42 PM
seawolf06's Avatar
-B
I know, but the Melling Select (thick casting) pumps are supposed to use bolt-on pickups.
Old Jun 15, 2007 | 05:54 PM
1racerdude's Avatar
They make a special tool to drive the stock and other press fit pickups in to the ridge on the tube without damage.
Old Jun 15, 2007 | 07:30 PM
blown383's Avatar
Yes... I have one myself! They also have a "L" shaped bracket welded on to the tube so that you can bang on the tube to get into the oil pump.
-B
Old Nov 3, 2007 | 10:10 AM
seawolf06's Avatar
Jeg's site said to use the 22110 pump, but it's not on their site and summit has it as N/A. Where did you get the 22111 pump from? What's the inlet diameter?
EDIT: The 22111 pump replaces the 22110 part number.
Old Nov 3, 2007 | 11:06 AM
speed_demon24's Avatar
Where can you get this? And do you still recommend tack welding the pickup on the pump?
HectorM52
Jul 30, 2017 11:46 AM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
